Rear Driveline Disconnect
This compact unit simply replaces the rear drive shaft flange of the Samurai transfer case. It is a great alternative for the Samurai owner who can take advantage of the benefits of all of the various new transfer case gearing options and have the ability to "burn-turn" or do front wheel digs......just like the guys with the Atlas cases! This rear drive disconnect made by Trail Tough works not only for the serious wheeler's burn-turning needs, but also works excellent for disconnecting the drive shaft for guys who just want to flat tow. Comes with all needed hardware and shifter handle.
Cutting a hole in your tunnel for shifter is necessary.
Samurai Driveline Pattern Flange
Price: $399.00
Toyota Driveline Pattern Flange
Price: $399.00
http://www.lowrangeoffroad.com/index.php/rear-driveline-disconnect.html
Во первых зачем это ? Что пишут в рекламе ? Чешу репу.
Я б поставил бы это для того что бы в каждодневной езде по городу,отключить лок райт !! :thumbsup:
( Если адаптор спидометра не будет мешать)
Какие мнения ?
