Функционал ЕSР???
Victor23
23 Апрель 2007
2,335
360
Нечерноземье
про ВВТ на дроме обсуждали и пришли к выводу сие имеет место быть и на право и на леворуких машинках
frugus
14 Май 2007
441
Москва, ЮВАО
cлеп я был.... вот что окопал в тех мануале...
This ABS is equipped with Electronic Brake force
Distribution (EBD) system that controls a fluid pressure
of rear wheels to best condition, which is the same
function as that of proportioning valve, by the signal from
wheel sensor independently of change of load due to
load capacity and so on. And if the EBD system fails to
operate properly, the brake warning lamp lights to inform
abnormality.
frugus
14 Май 2007
441
Москва, ЮВАО
оттуда же выдрал....
Camshaft Position Control (VVT Variable Valve Timing) System Description
S4RS0A1401002
System Description
The VVT system is an electronic control system which continuously vary and optimize the intake valve timing in
response to the engine operating condition.
The optimized intake valve timing produce such an air intake with high efficiency that both the higher power generation
and lower fuel consumption can be attained in the whole engine speed range from low to high. In the area of the
average engine load, low emission of nitrogen oxides (NOx) and high fuel efficiency can also be attained by making
the valve opening overlap between the intake and exhaust valves longer.
For the brief of the system operation, the intake valve timing is varied by the cam timing sprocket (1) which varies the
rotational phase between the intake camshaft (3) and sprocket. The rotor (2) in the cam timing sprocket is actuated by
switching or adjusting the hydraulic pressure applied to the chambers for the timing advancing (7) and/or retarding (6).
To switch or adjust the hydraulic pressure appropriately, ECM operates the oil control valve (12) with detecting the
engine speed, intake air value, throttle opening, engine coolant temperature and camshaft position (angle).
Jah
zoih подери!
22 Июнь 2006
4,257
1,039
Swift 4x4 2007 г.в.
Ога!
За сим полагаю ВВТ изм есьм!!! т.е. имеет место быть!
Enzo
5 Февраль 2007
525
266
Ответ: Функционал ЕSР???
Ну нету у нас ESP - НЕТУ!!!
Есть EBD!!! Кстати, неплохо работает. Только сегодня проверил - тормозил левой стороной на асфальте, правой на снегу. Авто сначала повело влево, потом застрекотала АБС, сработала EBD и машинка выровнялась.
2,123
Правильно, если бы было, то в презентации япы и Свифт показали бы:(
Another
14 Ноябрь 2007
Вот уж не знаю ребята с какой стороны у вас хорошо обсуждаемые тут системы работают... У меня если честно одно расстройство и сплошные заносы... 3 случая - первый, когда снегопад был, я еще не нашел себе зиму на машинку ( у многих помоему с поиском была трабла) еду километров 15, тошню до дома. Передомоной встает машина, касаюсь тормоза, бьет АБС, ничерта не тормозит но самое инетересное что зад начинает меня справа обгонять почти задевая А6 рядом... Второй, Еду по трассе, небольшой рыхлый снег, скорость километров 70, тут оказывается что на этой трассе на белом снегу сидит белая собака - руль вправо, немного тормоз, пытаюсь выровнять - ФИГ занос в одну сторону -раз, в другую два - 180, остановился. Ну и последний - условия такие же, скорость та же, длинный поворот 45 градусов, только сую в него морду, чуть касаюсь газа - результат тот же. Оба раза пронесло со встречкой и бетонными столбами...Рыдаю!
Вопрос - Мне хоть что-нибудь в этом случае должно было помочь из электроники? Или здесь только ошибки моего собственного ДНК?
З.Ы. Ни одна лампочка у меня на панели никога не горела кроме как при тесте ( я имею ввиду лампочки АБС и пр.)
Enzo
5 Февраль 2007
525
266
Кто ж тормозит в скользком повороте?
В теории ESP возможно и помог бы... Оно управляет тягой, тормозами и т.д. именно в таких ситуациях. Но, от резкого заноса врядли спасет, имхо...
grsl
8 Август 2007
242
vkontakte.ru
S-max '07, Swift GLX '07...
Ну тут тут некоторые столько не по делу написали...
Нет на Свифте ESP, у меня на S-max она есть...
В двух словах отличия от только EBD:
EBD работает только на торможении, выравнивая машину,
ESP (в состав которой входит и EBD) выравнивает и при газе...
petrovpetrg
6 Декабрь 2007
Одинцово-Внуково
petrovpetrg.ya.ru
swift серебро 434
вот все верно. при тормозах рабоатет. проверено еще в прошлую зиму :):thumbsup:
