про VVT к гадалке не ходи!Jah написал(а):а с ВВТ то чиво? есть оно или нет?
This ABS is equipped with Electronic Brake force
Distribution (EBD) system that controls a fluid pressure
of rear wheels to best condition, which is the same
function as that of proportioning valve, by the signal from
wheel sensor independently of change of load due to
load capacity and so on. And if the EBD system fails to
operate properly, the brake warning lamp lights to inform
abnormality.
Camshaft Position Control (VVT Variable Valve Timing) System Description
S4RS0A1401002
System Description
The VVT system is an electronic control system which continuously vary and optimize the intake valve timing in
response to the engine operating condition.
The optimized intake valve timing produce such an air intake with high efficiency that both the higher power generation
and lower fuel consumption can be attained in the whole engine speed range from low to high. In the area of the
average engine load, low emission of nitrogen oxides (NOx) and high fuel efficiency can also be attained by making
the valve opening overlap between the intake and exhaust valves longer.
For the brief of the system operation, the intake valve timing is varied by the cam timing sprocket (1) which varies the
rotational phase between the intake camshaft (3) and sprocket. The rotor (2) in the cam timing sprocket is actuated by
switching or adjusting the hydraulic pressure applied to the chambers for the timing advancing (7) and/or retarding (6).
To switch or adjust the hydraulic pressure appropriately, ECM operates the oil control valve (12) with detecting the
engine speed, intake air value, throttle opening, engine coolant temperature and camshaft position (angle).
А про ESP ни сказано ни слова...frugus написал(а):cлеп я был.... вот что окопал в тех мануале...
Правильно, если бы было, то в презентации япы и Свифт показали быНу нету у нас ESP - НЕТУ!!!
Есть EBD!!! Кстати, неплохо работает. Только сегодня проверил - тормозил левой стороной на асфальте, правой на снегу. Авто сначала повело влево, потом застрекотала АБС, сработала EBD и машинка выровнялась.
Вопрос - Мне хоть что-нибудь в этом случае должно было помочь из электроники? Или здесь только ошибки моего собственного ДНК?
З.Ы. Ни одна лампочка у меня на панели никога не горела кроме как при тесте ( я имею ввиду лампочки АБС и пр.)
Я видимо не так выразился - пытался хоть как-то остановиться уже после того как машину начинало мотать...Кто ж тормозит в скользком повороте?
вот все верно. при тормозах рабоатет. проверено еще в прошлую зимуEBD работает только на торможении, выравнивая машину,
ESP (в состав которой входит и EBD) выравнивает и при газе...
